Thread: Will any RR Sport wheels fit on a L322?
    Kingfisher Guest
    Cool Will any RR Sport wheels fit on a L322?
    Hi Guys,
    are the wheels on a Range Rover Sport all interchangeable with the L322 HSE/Vogue? Are the hubs, offset etc all the same?
    I like the look of some of the sport wheels for my HSE, mmmm...
    Adelaide Hills - SA
    The PCDs are the same for both.
    Are you thinking of fitting 19"s and do you have a Diesel? If so I can fill you in on a couple of things. If not - then they are not relevant.
    Kingfisher Guest
    No, maybe a set of 20s from the Sport. My L322 is petrol.
    Did the wheels change during the model life of the sport or are they all the same? (and same as L322?)
    thanks
    Jul 2007
    I think you will find that the wheel nut holes will be a different diameter and you will need different wheel nuts.
    Quote Originally Posted by slug_burner View Post
    Re an L322, I don't think so. For a P38A, yes. I have RRS rims on my P38A. The nuts are smaller than trhe P38A nuts but the thread is the same.
    Kingfisher, you're welcome to try my RRS rims on your L322.
