Darren, piece of cake, check out the thread by sclarke on disc brake conversion for county.
JC
can anyone tell me if its possible to change a drum brake salisbury in a 110 county to discs and if so how difficult..
cheers darren
JC
 AULRO Holiday Reward Points Winner!
						why does everyone want to change to disks?? drums are much better in the long run
My '85 County has had it done, but you need to go to 130 booster to maximise the potential. I think Clarkie did a tutorial on modifying a Discovery booster.
Anyway the poms have been doing it for years
Drum brake 110 salisbury disc brake conversion - LR4x4 - The Land Rover Forum
 Master
						Supporter
						Master
						SupporterHave a look here brakes sticky
This is the thread with all the good info on brakes.
If you have a look at the very first one it talks about how RR classic rear disks and hubs will fit straight on, in most cases. Which would be perfect for you if it going in a rangie. 110s generally should fit a bigger caliper because of the weight.
Dan.
84' 120" ute - 3.9 isuzu.
Just an added bit of info, I have a 130 DC Sals in my RRC and left the 'fender calipers etc on, no bias issues and they perform well.
JC
