 Originally Posted by
FatFreddy
				Add to below post, that the rivets chosen should be the sealed type to prevent ingress of moisture etc.  The reason I say this is 'Blind Rivet' is sometimes a generic term for pop rivet and if you get normal pop rivets from the hardware shops, they are normally 'open', ie do not have the end sealed.
Sealed rivets appear a bit longer than normal, but the grip length is written on the packaging.
Sealed rivets are not that common in hardware shops, especially in LR size, so a visit to a specialty fasteners supplier may be required.
Last time I got some, purchased a box of 1000 for all those little projects around the Landy.
FF
 X2 - You can never have enough rivets. Especially if you own two Defenders.
