Results 1 to 6 of 6
Thread: D2, V8, LPG - Drive down road engine stops
    Had number of breakdowns yesterday
    Engine just stopped, after 30 mins will start, 10 mins later engine stops
    NRMA out - no spark to plugs
    Car in garage - not fault codes to identify anything in particular
    Any suggestions
    thanks
    mike 90 RR Guest
    The D2 ... If you don't have the Dizzy cap with leads ... then you have a crank angle sensor ... It has most probably failed
    Mike
    d2 stops
    Dear Mike
    they are looking at the crank angle sensor - hopefully we are on the right track
    thanks
    Oct 2007
    Brisbane West
    Those sensors can just fail - not common but can happen (like any bloody electronic sensor on modern cars!)...and unless you have one in the glovebox and are handy its a bit of a problem. Anyway hopefully that should be it...does it do it on both LPG and petrol?
    Mar 2007
    Perth WA
    Alan,
    When the crank angle sensor dies the tacho drops. If you can get the car to cough and fire and the tacho doesn't move i'd change it.
    I have seen one 4.6ltr V8 that had the crank angle sensor mount break away from the engine block. That cause intermittent rough running and lose of power....
    It should take a competent spark/mech about 5 mins to diagnose a faulty crank angle senor
    Luke
    Crank angle sensor it was - thanks
