WOW - two of us on the same day who both replaced springs with Arnott Gen 3's.
Lavis i left the wheels on and just had the car raised in high mode. Pulled the inner wheel liner such that i could get my hand and a small screw driver to lever off the front clips and a long screwdriver for the others from inside the engine bay once i moved the air intake from the filter. Passengers side was harder than drivers. Rear were easy although one of my bags was stuck with mud and refused to drop (had to be the first one i did so had me scratching my head) all the the others just fell out. Amazing it is all held by two pins (rear) and a pin and 2 circlip arrangements on the front. Mine seems higher in standard mode so i will need to play with the settings to get everything right again.
Good photos and well done mate! Also attempted my winch install onto my ARB bar but need to get guidance on fairlead install.
Remy
