talking perfect world
bio diesel has better lubricity but is more viscous at lower temps and pressures
mix in impurities or dont make it right and who knows.
TDI300s operate under the margin for perfect bio causing problems in the mechanical way but the bio can take out the seals in the pumps/lines.
TD5's (and almost any common rail or unit injected engine) operate near or over the magic point where bio becomes problematic and even then if the bio is prefectly clean its not a problem till you pick up contaminants.
The viscosity in colder weather can cause problems getting through the filters but some clever use of heater hose soon sorts that out.
