Cost of an oil change on the Puma
					Got around to changing the oils on the Puma after the big trip and also to get the 15W-40 Valvoline crud out of the engine.  I'd had to order a new sump plug before I could do anything a I didn't have a spare.
Here's the rough cost breakdown:
Diffs - 4L Castrol EPX $40
Transfer case - 3L Castrol Syntrax $20/L = $60
Engine - 7L Castrol Edge (comes in 5L containers) $43/5L = $86
1 sump plug $8
1 oil filter $20
Cost = $214
From this I have unused (for next time around)
500mL Syntrax $10
3L Castrol Edge $26
Total cost $178
You need a new sump plug with the oil change as there is a rubber gasket attached to the plug.  Like any oil change I like to make sure that (a) I can undo the filler and (b) I have a bolt to put back in the drain hole.  So I had held off until I got one.  The old one becomes a spare.
There was also a squirt of grease on the Uni-joints and prop-shafts.
The rear diff oil was in good condition but the front was very black.
One other thing worth noting is the oil filter cover hex head is 27mm so you can use your wheel spanner to take this off.  How did they end up with that sensible a design
