Thread: changing rear brake light bulb
    Herbie Guest
    Hi All,
    This is my first post and have to admit it seems a poor way to start. We have a great 2005 Disco 3 S (this is our 3rd landrover) and i am stumped on how to change the rear brake light bulb.
    There has to be a simple way to solve this........any ideas?
    open the tailgate two philip head screws in the chanel undo them then
    pull on the whole unit it has two clips inside so takes a bit of force.
    It is best to grab the outside edge and pull.
    Hope this helps.
    Bigmac
    Herbie Guest
    thanks bigmac. was too worried about breaking the cluster. job is done in under 30 seconds. cheers.
    Not a problem i have had plenty of practice mine tends to blow
    the right hand side about every six months
    Bigmac
    300+ Guest
    Quote Originally Posted by bigmac View Post
    Bigmac
    You should check the earth. It shouldn't do that. One bad bulb can happen, but not that many.
    Cheers, Steve
    adelaide
    Unhappy D3 connock
    I popped a lhs brake globe, replaced it now when I have lights on and apply brake there is no light in that globe at all
    Queensland
    When your changing the Stop/Brake globes, if you don’t have new globes handy, use the rear fog light globs because LR very kindly installed Stop/Brake globes in the fog light fitting.
