Results 1 to 9 of 9
Thread: Fixing corrosion on Defender
    matthew2 Guest
    HI ALL
    I have got a 2001 Defender and its got corrosion on the hinge like brackets under the front windscreen ,the paint is peeling off .
    What can i do to fix the problem?
    Freestyler Guest
    If it is on the fire wall you want to fix it quick as it is steal. clean it back as best you can and us some rust converter. Also have a look around the LHS bracket where the windscreen is bolted to on the inside in around the vent. I have a 94 defender firewall in my county and that is where was rusty. Tim
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    If it is just the brackets, remove them and either replace or clean and repaint them. If it is the metal around them, particularly the firewall below, remove them and see how bad the situation is, as for last post. Having removed the bracket check the hole through the firewall as well. There has probably been water getting under the bracket - make sure it is sealed properly when reassembling.
    Nov 2006
    Wollongong NSW
    Quote Originally Posted by matthew2 View Post
    HI ALL
    carefully sand etch prime and paint
    better. take it off bead blast sand etch prime and paint..............
    Caboolture.Qld
    You will need to take it all back to bare metal, apply rust converter and when dry/deactivated apply cold gal. and a primer then top coat.n Keep an eye on it.
    matthew2 Guest
    Thanks guys for the info! My Defender is starting to pee me of first was no power when towing my boat particulary up hills then leeks water ,crap steering circle ,oya cant for get the spine bending disc crushing experiancse when driving long distances. A real Diamond of a 4x4 ! I hope Iveco Massif comes to Australia will be looking at seriously as well as the Toyota HJ40 the new one .
    Melb. Vic.
    They all leak
    Turning circle - you can wind the stops in a bit or get used to it
    Ride Qual - I'd be checking yr springs/shockers - Mine is stock and has a nice ride. Firm but fair!
    Power - Depends on the size of yr boat, I guess - You can get the Td5 tuned for a lot more power if you choose - 180Kw is possible - 120 to 150Kw pretty easily.
    (Intercooler and Chip)
    Yeah the IVeco looks ok - not sure what a HJ40 is (I used to have a BJ40 - now there is a bone crusher !)
    Freestyler Guest
    My county dosen't leak, will flog a Toymota for turning circle, power, cost of running, ride...... The list goes on. If you hate Land Rovers you will get a shock if you buy one of those over rated jappanies 4wd!!! My biggest gripe is with toymotas is that they can't get where I have had my landie.
    Perth W.A.
    dude sounds like you bought the wrong motor you should have bought a toyissan they have no character at all and fall apart just like everything else.
    You need to learn to love it, it will be faithful if a little wayward at times it's a land rover thing
