                                                3rd November 2009, 08:00 PM
			Circlip Failure in LT85 GBox
					I posted a bearing failure in an LT85 Santana box a while ago, have had the circlip break on the back end of the main shaft and has stuffed both gears on 5th. I reused the circlip which was only aprox 3 months after the original rebuild after the layshaft bearing failed. I guess this was an expencive mistake. I have also had the ports on the head opened up and matched inlet and extractors. Also bored out the throttle body on the EFI manifold and had a larger butterfly fitted gas injector nozzels installed. The petrol computer has been rechiped and going realy well and excited to see who the gas goes when injected. I also think we need our own section for county's.
 Tim
