Results 1 to 9 of 9
Thread: Heater bypass required.
    Oct 2008
    Hi Guys,
    As I am presently running no heater does anyone know where to get a heater bypass from, it basicly just connects the two heater hoses together in a u shape.
    Thanks Ben
    dmdigital's Avatar
    You should be able to get by with a straight hose joiner, but a 90 degree one may be more suitable. You could also try a hose specialist like Enzed if they are local.
    At least you can bypass the heater, my blower's been cactus for a few years now so I have no fan. Makes demisting the windscreen fun.
    in the wild New England, NSW
    you can look up one of these catalogues
    Mackay Consolidated Industries
    and choose the shape/diameter you need, or
    Repco and the like have universal "Z" sections in the usual diameters which by themselves or in combination will let you do what you need
    Somewhere else, QLD
    I know this sounds weird - but I rummaged thru the supercheap radiator hose section until I found a preformed hose 5/8 (19mm) that had a u-shape. It was $12, and after I cut the excess off, it fitted perfectly. ( The label said it was for some sort of Holden, but I used it for the extra air system on my flapper efi).
    In the near vicinity to the radiator stand should be some blanking caps in the same size - they work well too and look neater
    Jul 2008
    Banana Qld
    I have not connected the heater up in mine since a body swap. Just a couple of bolds clamped in hoses.
    Oct 2008
    Thanks, went to repco and got a right angle works perfect cheers.
    Ben.....
    Perth W.A.
    i took the heater box out the deefer and used a bit of copper pipe and some jubilee clips happy days ..haven't got a pipe bender do ya ???
    Oct 2008
    Quote Originally Posted by lardy View Post
    I wish ......
    Central Queensland
    wouldnt it be easier to just replace the existing hoses with one shorter hose and forget about joining the existing hoses?
