Results 1 to 6 of 6
Thread: 1985 V8 County Strange Plastic Tubes
    Castle Hill, Sydney, Australia
    Guys,
    I have recently acquired my first LR (unregistered) and I am working through fixing some problems and familiarising myself with the entrails.
    One thing that has me psuxzzled are 4 white plastic tubes that run from a rail mounted on the firewall. I have traced two of the tubes to mounts on the front and rear axle cases, and the other two seem headed for the gearbox area. There is a rubber hose connection to the rail that has been cut.
    Any ideas on what was attached and what this system would have been for?
    Dec 2008
    Victoria
    Sounds like extended breather tubes - stops water from creek crossings being sucked in past the factory originals which were sitting nice and low on top of the axles/diffs and transmission [gear box/transfer case]. A good thing to have.
    Melrose SA
    My guess is that they are gearbox breathers usually terminate on the LHS of the engine bay.
    They are mounted high to prevent water ingress
    Many thanks...that makes sense. I will leave well alone.
    Djam guesses right
    Oct 2006
    The Vines WA
    Like Djam said.
    On mine, one pipe is for the gearbox, one for the transfer case (plus the two axle breathers you have already identified).
