Thread: 300 TDi Viscous Fan Shaft Bearing
    Reef Inmate Guest
    Hi there
    Does any one know the part number of the bearing that the viscous fan shaft runs on and how to change it?
    Thanks in advance to all the Gurus who know.
    I have been told by our local parts suppliers I have to buy the whole cover at a huge cost.
    Im sure I can get a bearing from a local bearing supply, just need the number and how to remove the old one and fit the new one without destroying the cover/casting
    Torres Straits
    Search for "300tdi Viscous Fan Bearing - SOLUTIONS!" in projects and tutorials under my user name... all answered in the post
    S
    Aug 2008
    Roverrescue has indeed solved your problem with his excellent tutorial!
    ..but just in case your aren't up to speed on navigating this awesome site: http://www.aulro.com/afvb/projects-t...solutions.html
    If you decide to take roverrescue's option 3, one place the bearing can be sourced from is: http://www.british4wd.com/xcart/search.php'mode=search
    Good luck!
    Somewhere else, QLD
    And as a third option -
    Land Rover Bearing ERR7146BRG
    Rydalmere, Sydney
    Fan bearing
