Results 1 to 3 of 3
Thread: disc backing plate
    May 2009
    disc backing plate
    Hi all can someone tell me whats with the front disc rotor backing plates that like breaking off there mounts,mine has done it and so has my mates,is this a fault? do i buy new ones or do i just pull them off......wes.
    Castle Hill, Sydney, Australia
    I assume you mean the disc brake shield that is there to keep crap off the discs? Do you have a lot of vibration up front? I would not throw them away! weld them up with a bit of reinforcing....and paint the weld so it does not rust.
    Take them off and throw them away
    More Hassle than they are worth . The clips always rust away or stones get caught beteen them and the Disc and make a hell of a noise. Or they bend slighly and then touch the disc make a horrid noise you spend ages trying to find
    Normally in the Uk they fall of with in a couple of years anyway
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
