12th November 2009, 07:31 AM
What Mitsubishi TD04 Turbo on a 200/300TDI
If a 200/300TDI is converted with a Mitsubishi turbo, what Mitsubishi TD04 Turbo is used?
From what car/model/year?
I mean kits like:
- MTQ/ DTS
Bart
12th November 2009, 08:05 AM
TD04L off Subaru WRX. Should be able to get as new one off ebay for around $300-$400, as they dump them for a larger unit when speccing the car for rallying. Some have only a few k's on them...
12th November 2009, 08:07 AM
p.s. don't forget you won't get the results in the graph without tickling your injector pump. The TD04L will come in at lower RPM, but more air doesn't make more torque. You need extra fuel in the mix.
