Results 1 to 6 of 6
Thread: d1 into d2 cargo barrier?
    as i already have a branded cargo barrier in the d1 i was wondering if it can be fitted into the d2. are there parts available for the conversion? i really would like to do this as the d1 will eventually be put up for sale and the other bits on it are not transferable but will go with the car
    If it's a Milford barrier why not contact them direct. The mounting in the D2 is definitely different so the straps will need replacing (at least at the top). Milford should be able to tell you what parts are needed and then any stockist could order them for you.
    tried that first off still no reply might call around to a few retailers this morning
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by trog View Post
    They are about the same size as i have a D2 barrier waiting to be fitted into my D1, different mounting straps will make it work.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Apr 2007
    I am lost
    Lets make it easier Trog and loanrangie do a swap ,problem solved
    Williams West Aust
    They dont fit.I have one in my D2.
    Not worth trying to fit correctly.
    I built my 80lt Engel fidge unit and cargo barrier Ex the D1 barrier I bought from an AULRO member.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
