You  need to remove the door trim panel before you can remove the latch. But I suspect that is what you are trying to do! To do this you need to remove the plastic trim around the latch.
This is in two parts, split horizontally at the mid point. The two parts of the trim slide up and down - start them by levering in the join or at the top and bottom between the trim and the latch body. You may find that pushing in on the door trim panel helps them to move.
