Results 1 to 10 of 21
Thread: 2 stroke in fuel
    Nov 2008
    2 stroke in fuel
    there are heaps of threads on there about puting 2 stroke oil in ur fuel tank with normal deasel,
    would just a lil bit of just normal engine oil hert instead of 2 stroke oil??
    and what about eny other oils, has any one herd of other things people are willing to put in there tanks,
    and this is on a td5?? iv tryed 2 stroke with a few tanks and it is a tiniy tenie bit smother sounding with the engine cover off, but with it on no diff at all,??
    Brisbane, Inner East.
    Quote Originally Posted by stig0000 View Post
    Distillate is a light oil with additives like butane at differing levels for startability according to season, rust inhibitors, etc. So all you are doing is adding oil to oil. Can't hurt and may improve the lubricity of current distillates.
    URSUSMAJOR
    DougLD Guest
    Hi All
    This is new to me what amount do you add to a tank full and what benifits do you get from it.
    Doug
    Sep 2009
    brisbane
    Quote Originally Posted by DougLD View Post
    Hi All
    Doug
    i use 300ml to 70 liters of diesel,also use only semi synthetic 2 stroke oil,helps injector pump and injectors last longer,slightly better MPG,cleaner burning,less black sort from exhaust.
    This is not an old wife's tale.
    Mercedes use 2 stroke oil mixed in with diesel on there test cars as the "Euro"diesel is not as "slippery"as the old diesel.
    Manufactures are coating moving injectors/parts in a type of Teflon to try and get pumps etc to last through there warranty periods.
    The 2 stroke semi synthetic oil completely blends with the diesel.
    Hope this is of some help.
    Sep 2009
    brisbane
    Quote Originally Posted by Brian Hjelm View Post
    There are different types of oil with different levels of ash and other additives.
    All oils are NOT the same.
    So you cannot just pour any oil into your diesel.
    Quote Originally Posted by defend View Post
    Diesel engines are run on oils from distillate to the bottom grade sandy tar used in big marine engines. Lube oil is not that different from distillate and diesel engines will run quite handily on it. Consider this, you are only adding a miniscule amount of two stroke oil to your distillate and most unlikely to do any harm. Systems that clean sump oil and meter it into bulk fuel storage have been used by fleets for decades.
    URSUSMAJOR
    Nov 2008
    im taking it you wouldent put just used sump oil in then,
    had a frend on a farm that run out of dasel and stores all his used oil in drums,, just pumped 50L of oil into his car to get him to town and back , he sead the car ran no diffrent, and has never had a problem
    and so now wen the price of fuel get to hig for him he puts his old oil back into his tanks, he recons it ant gona hert it,
    Aug 2008
    Alice Springs
    Hi all,
    I add 300ml 2 stroke per full tank of deisel in my 98 Disco 300tdi, there is no dought in my mind that it runs smoother and quieter.
    I read about others doing it on another forum and thought why not. I'm convinced that it has increased my cars performance; however I have no way of quantifying this.
    My tdi has 210k on the clock and its running the best its ever been.
    mighten't suit others but it works for me
    Regards to all Jim
    DougLD Guest
    Hi All
    I am going to try it when I fill the tank next time i have now read a few threads on different forums and i have not seen anyone saying that it has damaged the engine. Mostly good reports so I will try it.
    Doug
    Safety Bay
    I'm one of the biggest critics of this type of thing mainly because I see and have to fix the end result of a lot of these practises.I would advise that only 2 stroke oil be used and only in small amounts,remember that most of these idea's are there to make savings,savings that are no where near covering the cost if things go wrong. Pat
