Results 1 to 8 of 8
Thread: Acronis,,
    May 2003
    On The Road
    Acronis,,
    When I bought the two black WD HDD's I got a copy of Acronis True Image.
    I use this to backup my data,,
    my question is,,
    if I wish to USE that backup,,
    what happens to the weeks worth of data not backed-up,,
    (the thing is,, its THAT data I am trying to get rid of---)
    Jun 2008
    McMinns Lagoon NT
    Where and how are you going to restore?
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Nov 2006
    Tasmania
    Hi,
    I use Acronis to image whole HDDs and it works great. For just backing up data you can use COBIAN. Its free and works very well.
    Matt
    Jun 2008
    McMinns Lagoon NT
    Quote Originally Posted by Roadrunner View Post
    Hi,
    Matt
    What do you use True Image or Migrate Easy?
    Cheers, Dale
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Nov 2006
    Tasmania
    True Image.
    I built computer and clone most of them. Use it for cloning/backup of critical Windows server as well. Picks up the raid drives and I can clone it to a single HDD. Have a test server in the office and connect the cloned HDD to make sure everything works fine.
    Someone else I know uses clonezilla and loves it. I haven't tried it but will give it a go.
    Matt
    Somewhere else, QLD
    For Pedro -
    I've used Acronis when I had a desktop PC, and the spare drive was a plug-in external. There was a time when something I did screwed up the OS so that it was desireable to go back to before the event, and it was as simple as swapping drives (Either physically or in boot up order). Acronis took no notice and everything was fine. Since it rewrites the entire disk, then it is as if the previous week had not existed. Good for if the HDD actually fails.
    Jul 2009
    We just went through a nightmare universal restore with Acronis. Its a damn good program and works well - until you stick it near host-raid. Then its as slow as all hell. Proper raid cards aren't a problem.
    I set my servers up to image once a week to an external tape drive, then we run daily tape backups to LT03 drives. (and as an extra precaution as we have the room, we also put the acronis image on the tape drive as well...) works well, havent had a failed restore yet! (although a few missed backups due to the lackies not changing the tapes over of a day. :/
    May 2003
    On The Road
    The good news is Acronis will just write over the original drive,, deleting any extra data.
    C drive just requires a reboot to happen,,
    Acronis,, works like a charm,,
