Few Q's - does it happen in neutral if you rev the engine?
Does it happen in both high and low range? A clutch thrust bearing will whine or "growl" when the pedal is depressed, then stops when it is released (as long as it's all functioning properly).
Have you checked the oil levels in all the boxes?
Where abouts does the whine appear to come from (front/back/left/right.
Is there any associated vibration?
Any other odd behaviour? (coolant loss etc)
Does it happen more if you have more electrical equipment on? ie lights, stereo etc
Reason: extra Q
1974 Military Lightweight Landy --- Some dementia at 50 years old
2000 Disco series 2 now sadly moved on!
No5 Trailer joined the fold... Awaiting graduation to road licensed!
2021 Mazda BT50 or is that DMax?
