Results 1 to 10 of 15
Thread: Td5 Cooling
    cam.mclay@bigpond.com Guest
    Td5 Cooling
    I've got a 99 130 Defender Duel Cab. I live in Geraldton WA and last week did a trip to Perth about 430 k's. Coming back two days later I had done about 100k's and the temperature guage moved up to high. I pulled over and coolant was coming out thru the overflow tank. I then limped the rest the next 330 k's at about 70kph and stopping every 20 to 30 k's. Since then I have had the radiator flushed and a new thermostat put in. Bringing the car home from the radiator place the over flow started bubling after 10 k's - just as I got home.
    My theory now is the water pump is knackered. My main reason for thinking this is that when the engine is cold and I take the air bleed plug out of the top radiator hose there is no water being pushed out -only the trickle from gravity from the overflow tank. Before I ****-fart about pulling the water pump out I would appreciate anybodies thoughts on this matter.
    whisky Guest
    Td5 cooling
    Hi you,
    Did you Check the presure In the coolent system?
    I had kind of the same problem, the sill between the head and the block was demeged, I had to replace the sill.
    The way to understand is some simple test's:
    1. gas in water test.
    2. presure test of the coolent system (not working engine, and again when the engine workes).
    If the presure gets high when the engine is working, and it mekes the coolent liqued push out of the over flow tank, than it probebly meens you have a problem with the engine head sill that lets air from the chambres (cylinders) get to the coolent system.
    any way, dont drive the car untill you solve the problem since it mighet demege the engine block or head or the two of them.
    whisky
    Melrose SA
    I would be inclined to take it out to Whyatts and have them check it over.
    If a TD5 overheats on the gauge its usually done damage from what I understand.
    Must admit I would be thinking its probably done the headgasket I am afraid. How hot did it get? I can't imagine the water pump would fail having had one out recently.
    Rgds
    Pete
    TBA
    I'd be inclined to agree with Pete
    My brother had a very similar experience with an early model Td5
    The early models have plastic head dowels which melt/break when they get hot. This allows the head to move just that little bit which in turn buggers the gasket
    Again like you he didn't have oil in the coolant or any of the normal symptoms of head gasket failure. But he was losing coolant like yourself
    I would strongly recommend not driving it until your certain it's not the gasket, Td5 heads are expensive
    TDI Cooling
    Thanks for your ideas. I've had the vehicle about a year. I thought it could have been the fan but once the heat goes up the viscous coupling locks rock solid. Everybody I've talked to thinks it pretty unlikely the water pump would pack it in as they don't work very hard but I read on one of the threads that one bloke had taken his apart and one side of the drive key had come away. Plus it will be easier to check the water pump initially than to pull the head off.
    Regards,
    Cameron
    Tdi Cooling
    There is no bubbles or oil in the coolant overflow tank. Well I'm off now to pull the water pump out.
    Regards,
    Cameron
    Good idea to take the water pump out first to have a look. Good luck!
    whisky Guest
    Td5 cooling
    Hi there,
    I hope the problem is the pump, but if you can get to a mechanic or get the toll in the pic do the test.
    if there is no lick in the system when you aply presure, It meens the system should be fine, If there is increase of presure (above the recomended LR book, I dont remember it now) than you need to chek where the presure comes from.
    Now, there are some reasons for the fluid to get too much presure, either there is a block somwhere (one of the hoses is full of something from previos owner) or the sill is no good, anyway. since your engine suffered from to much hit, I run the test, just to know the head is fine. the worse that could happen is a head or block crack and you dont want that to happen ($$$...)
    whisky
    Tdi Cooling
    Thanks Whisky - I havn't taken the water pump out yet because I was thinking abount your advice and might pressure test the system first.
    Regards,
    Cameron
