Thread: SWIVEL HUB OIL
    Sussex Inlet. N.S.W.
    SWIVEL HUB OIL
    Having just redone front bearings on my 110 defender I need to top the swivel hub oil as bearings are oil fed. What grade of oil should I use? Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    80/90wt gear oil.
    85/140 if the hub seals a little off
    you can also add a little moresy or stop leak to the same effect.
    Aug 2008
    Use whatever you have in your diffs, as Blknight said: 80/90 or 85/140 are good.
    Safety Bay
    It all mixes up so diff oil is the go.I use 85/140 in everything but the gearbox in my defender. Pat
    Perth W.A.
    Quote Originally Posted by PAT303 View Post
    i started using hi-lo milk in mine but it splits, so have gone back to full fat is a lot better!
