Results 1 to 4 of 4
Thread: Importing parts etc
    Sussex Inlet. N.S.W.
    Importing parts etc
    I know a few of you import parts from overseas. What is the max value of stuff before import duty applies. If I go over and have to pay duty, what is the rate at which I will be charged? Thanks, Jim.
    Jim VK2MAD
    '17 Isuzu D-Max
    May 2002
    Heathcote (in "The Shire")
    Pretty sure if the value exceeds A$1000, which includes, freight/postage,any insurances and GST (if applicable), you will then be up for customs duty. I don't think GST comes in until you are over A$1000 as well.
    I'm assuming you are talking about a 'casual' import not as a business.
    Do a quick hunt on Customs home page
    although this may have what you need Customs procedures for importing and exporting
    Martyn
    yep, that.
    went through the same deal when I was organising the diffs for the comma event.
    Brisbane, Inner East.
    Personal imports, not commercial, A$1000 invoice value. Safest to get sent via post, not commercial freighter, also cheaper. Post delivers to your door, aand no involvement with Customns or agents. If importing from the USA and your consignment is maximum 20lbs. weight or can be split into parcels of 20lbs. or less then use US Postal Service flat rate boxes. Check their web site.
    URSUSMAJOR
