just have a look in your owners manual......................![]()
Does anybody have a photo showing where the belt for the 200tdi aircon goes. mine is disconnected and i'm trying to work out what is required to re attach it.
1994 Discovery TDi
2004 Discovery 2 TD5
2010 Discovery 4 TDV6
Looking from the front of the motor. On the outside ring of the compressor, past the power steering pump (logic says it should go round it??) down to the main pulley (bottom of the motor) up to the tensioner pulley then round the a/c compressor. Hope this makes sense and assists.
Ok, so it loosks like i'm missing a pulley or tensioner as the ac has one belt, and the power sttering another at the moment. Thanks fot that.
does anybody have a photo for reference?
1994 Discovery TDi
Sorry I can't help with photo's. Mine has three belts. A/C belt, Power steering belt, (main crank to Power steering, Power steering unit has the adjuster-tensioner built into the bracket) then a small belt from the power steering pump to the alternator which has the adjuster- tensioner as part of the bracket.
All in all its a bit of a strange setup compared to other cars that I have had but is a Landrover after all!!
PM me your email address and I'll take a shot of mine this arvo and email it to you.
Martin
Ok, here is one of the photos that Martin has kindly sent me. I need the belt, that much I know, however I also need the pulley that can be seen on the bottom LHS of the image.
Does anybody know the part number for it???
1994 Discovery TDi
a look at some photos I had of my vehicle, and the reason why the aircon is disconnected becomes apparent!!!
1994 Discovery TDi
Hoooooly crap!
Hahaha!
Is that pulley just a jockey (ie free spinning) or is it connected to something?
[B][I]Andrew[/I][/B]
[COLOR="YellowGreen"][U]1958 Series II SWB - "Gus"[/U][/COLOR]
[COLOR="DarkGreen"][U]1965 Series IIA Ambulance 113-896 - "Ambrose"[/U][/COLOR]
[COLOR="#DAA520"][U]1981 Mercedes 300D[/U][/COLOR]
[U]1995 Defender 110[/U]
[SIGPIC][/SIGPIC]
I think it's free spinning, but on a spring arm. it's an elusive thing parts wise. I'll have to have a look at some of the parts books tonight.
edit: i've found the part number, 614718 by the looks of it, which is also common to the v8. and my brother has a block not being used that may have one. I'll have to check!
1994 Discovery TDi
