I came across this, might see if I can acquire one.
Solid Carbide Drill-bit
Now this is a beast. It will drill and cut into a screw and stud extractor (also known as an "easy out") — an extractor tool for a broken stud/bolt, and these are made from quite hard steel in their own right.
There is also a fair chance that it could cut into any of the above drill-bits, if you could keep it on centre.
