Dobbo,
The purpose of a shock absorber in a suspension system is to absorb the rebound energy of a spring after it's been compressed (i.e. to dampen its rebound motion). The absorbed energy is dissipated as heat within the shock.
In normal sealed road operation, the shock absorbers aren't working very hard as the suspension isn't moving up and down very much. On corrugations (and especially at speed), the springs are constantly being compressed and rebounded, resulting in rapid heat buildup inside the shocks. As the oil inside the shocks heats up, its viscosity increases and its ablility to "absorb" the spring recoil energy decreases. This is known as shock fade, and results in "sloppy" suspension characterised by excessive suspension travel and reduced handling.
To then answer your question, in running dual shock absorbers, each shock is only dissipating half the spring energy, so the suspension system is more resistant to shock fade. Also, monotubed shocks are more resistant to shock fade than dual tube ones, as they ecn better "give up" their heat to surrounding air.
Polybags or HD springs with helpers on the other hand are part of the "spring" in a suspension system which is related to load carrying ability of a vehicle. All other things being equal, a vehicle with stiffer springs for example will be able to travel over corrugations with more weight before bottoming out type thing... conversely, an unloaded vehicle with stiff springs will have reduced wheel travel. Choosing spring stiffness should be based on the type of driving the vehicle will do, and its laden weight. It is a compromise between load carrying ability and wheel travel when unladen.
That said, standard disclaimer applies - you have to make sure all other components of the vehicle can handle the extra weight (axles, chassis, braking and steering systems etc).
hope that answers your question.
...nehow, hope that's
