Is that Maxi or HyTuff?
What is a couple of maxi flanges worth? I have just been quoted $150 a side. Jim
Jim VK2MAD
'17 Isuzu D-Max
Les Richmond has them for $130 each, there's enough to buy a case of **** for ya, gota be happy with that.
Or $127.55 at Graham Cooper Automotive.
Or 90 British Pounds a pair at Ashcroft in the UK.
I've seen lookalikes on Ebay for that much a pair. Don't know if they are as good.
Land Rover Defender Heavy Duty Axle Drive Flanges - eBay Other Suspension, Steering, Suspension, Steering, Car Parts, Accessories, Cars, Bikes, Boats. (end time 06-Dec-09 11:51:17 AEDST)
Jeff
 Master
						Master
						cant remember what he sells them for, but the hi-tuff ones aint worth the money.
the last set i bought i had to open all the holes up by 1mm to get the bolts through and i've even got shot of their axles cos they're not much better.
go ashcroft and know you've got something that is worth the money!
84 Alfetta GTV
Must admit I was pretty happy with the HyTuff rear axles and flanges I fitted a few days ago.
These are the thicker Hytuff ones:
How do you work that out?
The bloke who used to work for Mal Storey making Maxi-Drive Axles is the same bloke that is Hi-Tough who now makes them for himself and they are made out of the same material, using the same brooches to cut the splines and heat treated in the same place.
Re the flanges: they are designed to be a press/tolerance fit onto the halfshafts and any movement you have in the flange bolts is movement on the halfshafts. Do you know that your flange bolts have not been replaced with non-genuine items? In which case you would have to blame the bolt manufacturer and not Hi-Tough.
Diana
BTW: I'm not suggesting that Ashcroft gear isn't good, it is just that I don't understand how Hi-Tough could be different to Maxi-Drive. However I will disclose that I have good dealings with both Maxi-Drive and Hi-Tough.
