Results 1 to 8 of 8
Thread: Replacement Tail shaft?
    Hey guys,
    After a mishap the other weekend out bush, which i thought it was just a broken uni joint, I took the shaft into the shop to get repaired as the ends of the shaft were a little flared out... I was told it was pretty well shagged, the ends were stuffed, main shaft was badly dented and the spline for the slip yoke, ( i think thats what it is called) was on its way out... He said he mabey could repair it ( with no garentee) for around $350 or make a new one for $650....
    Do those prices sound right to you guys???
    Has anyone ever had one made and is that around the right price, or does anyone know of where i could get even a 2nd hand one from.. I tried british offroad but they had none out in the yard..
    Cheers guys
    Mikey
    sounds a bit high try MR automotive.
    Jan 2008
    Sydney, West
    to me it sounds ok, I had my rear shaft rebuilt in darwin, new slip joint fitted basically, and that was 660
    Jul 2008
    Banana Qld
    What drive train have yu got?
    I have a rear tail shaft from a Lt95 to a sal off a 85 county, I think it was in good condition when I took it off.
    Quote Originally Posted by Albert View Post
    Is the lt95 a 5 speed?.. if so then yeh, mines an 85 county v8 5 speed..
    What sort of $$ are you lookin for it if you still have it albert..
    Mikey
    Aussie Expat in NZ
    Quote Originally Posted by Mikey0211 View Post
    nope, the LT95 is the 4 speed. You (most likely) have the LT85.
    ahh ok... anyway, got it all sorted this afternoon.. ended up gettin a 2nd hand one from landrover spares in gympie for $150.. .. Should keep me goin for a while anyway
    Mandurah, WA
    a double carden joint from hardy cost 800 half price mine, using original shaft, td5 with p38. a new double carden from mm4x4 in uk is 310 plus postage.
