Results 1 to 10 of 12
Thread: Chassis flex - how much is required?
    Nov 2008
    Mostly over there
    22.04 MB
    G'day all,
    Just been reading a few posts that raise concern about the lack of chassis flex in a 110.
    I have just recently rebuilt and strengthened my tray-back on an old 1984 110 cab chassis and have attached it to as many points on the chassis and end member as I could. I did this because I have fitted a mid mounted winch to the tray-back frame and I wanted the winch load to be transferred to the truck as much as possible.
    In constructing the tray back I may have made it lacking the flex it used to have, so this begs the question - how much does the 110 chassis need to flex? What sort of movement is good between the tray-back and the chassis?
    Phil
    PS, am looking for time to start a thread about the winch mounting but have been very busy at work so it will be another day.
    landrover chassis are not designed to flex because landrover can build decent offroad suspension.
    fozzys got a long split in a weld on the chassis and the handling is very very odd when you have chassis flex.
    Chassis flex is usually reserved for vehicles that have a c section chassis.
    heres a test
    grab a piece of thin steel shim or cut a section out of a coke can fold it and then repeatedly bend and unbend the shim. What happens?
    think thats a good idea for a chassis?
    no, me either.
    Nov 2008
    Mostly over there
    22.04 MB
    G'day Dave,
    What you indicate makes perfect sense and I have made the tray-back ridgid for a reason to avoid movement. This has turned out the right thing to do then based on what you indicate regarding the 'c' sections and box sections differences.
    Flexing like a coke can would not be good for handling - no. The noise would drive me nuts!
    Phil
    Brisbane, Inner East.
    In the early days of motoring and on the appalling roads of the time, it was chassis flex thet made the reputations of the American cars in the bush. The alloy steel frames of the Ford "T", Dodge 4's, Buick, Hudson, and others withstood the hammering from the "roads" and the flex gave extra suspension movement. The rigid steel frames of the Brit and Euro sourced vehicles cracked and broke up badly in outback service.
    Any surviving members of the outback mail and passenger carrying fraternity will confirm that they would have gone broke using English or European cars.
    URSUSMAJOR
    But..
    Get a Defender fully crossed up, & you can eyeball the twist across the roof panel. There is some flex there, whether good or bad.
    Max P
    Blue MTNs
    no, me either.
    I think this analogy is wrong. You are talking about flexing the coke can beyond it's point of elasticity, if you don't go beyond the point of elasticity, it will survive thousands of flexes. Your saying a Landy chassis should be stiff for longevity, this would reduce the Chassises elasticity causing welds to tear. The stiffer a metal object is, the easier it will crack if as it's window of elasticity is smaller, If not pushed past it's elasticity point, it would be fine. But still offer less damping to vibrations etc.
    I'm not saying Landys shouldn't have stiff chassis(to a point), I'd just imagine if it's too stiff it will probably shake to bits or crack.
    Oct 2007
    wetherill park
    In landys its the driver that shakes to bits, sometimes its the suzi engine there is some flex but not much
    Melrose SA
    I know the old HJ45 Land Cruisers would flex upto 6 inches from one corner to another I dont know how many times I ended up with them so badly flexed that I couldnt get out of the doors lol.
    Land Rovers dont Flex much at all even with the leaf sprung ones.
    The Land Cruisers in used hard use to break in halves after about 12 years of hard work but many 40 year old Land Rover have no issue.
    In Africa they use to plate both Land Cruisers and Series 3 Land Rover chassis the Series 2 and 2A never broke up even under the most extreme abuse provided they were not rusty.
    Jul 2008
    Windsock,
    What you have done by rigidly connecting the tray to the chassis is create two load paths. One the original chassis, the second the tray back - the load that the tray bay carries is directly proportional to the relative flexural stiffness of the chassis and tray back.That is that tray back is now part of the vehicle.
    The original chassis will be fine, it now carrying less load then before and for what is was designed. Will flex less, so a little less wheel articulation, doors wont bind as easy, etc.
    But the tray back is now acting as an integral part of chassis and needs to built as so it is part of the chassis. Have good quality ductile welds would be my main concern - metal fatigue over rough roads may be an issue. But if all the work high grade and considered as part of the vehicle can not see a problem.
    Clive
    Nov 2008
    Mostly over there
    22.04 MB
    Hi all,
    Thank you for all your responses. I was too busy this morning to shrink and then upload some photos but this afternoon I find myself waiting on others so thought I'd put some photos to the thread.
    First one is of the end of the truck showing how I bolted the tray-back to the rear cross member. All flat steel was 75mm x 5mm. All bolts are 10mm 8.8 tensile. All surfaces are flat to each other with no rubber inserts. It is all my work from the hook down. I used to be a fitter welder in the days before modern MIG so it is all stick welding old school stuff.
    I have then bolted the tray to the flat pieces of framing along each side of the fuel tank. The footings of the tray are sealed box section (75mm x 50mm x 4mm) welded onto 50mm x 50mm x 6mm angle iron. The tray frame itself is a mix of old (imperial 2" x 1") and metric (50mm x 25mm x 3mm) tube. I rebuilt the tray from the chassis up to the lateral frame. The main frame had rust so is new steel, the cross members had rust but I had no more steel so had to patch at will.
    At the front of the tray I have attached the frame to the two mountings you see here... although in the photo I have yet to drill the small hole you see there.
    I do not have an individaul photo of another bolting point, that of the small flat mounting plate just to the top right of the second photo.
    I figured with all there fix points the loading on the winch is going to be transferred from the tray frame into the chassis with a minimum of stress at any one single point. Even though the winch is coming out the rear only at this stage it is intended to route it through to the front when time and funds allow over the coming few weeks. Out the back will suffice for the time being as I needed to put the deck back on for carrying a load of stuff. Once I have time to go through my build photos I will construct a build thread of the whole winch install.
    Thanks again for your comments re the chassis flex. Good points all of them.
    Phil
