Modern Impeller design and more importantly modern coolants have eliminated any significant Impeller erosion due to cavitation.
The coolant system is NOT flow or pressure regulated to produce an ideal amount of back pressure for the pump. ALL Water Pumps cavitate.
There are still people around that say you should change your spark plug leads regularly. Back when Fangio was King that was true, but we won't go there.
The cooling system is only temperature regulated. (Not withstanding the spring loaded cap)
