Results 1 to 10 of 17
Thread: 2a body on a RRC chassis
    Jul 2008
    Brisbane: Sunny Coast & Nth Straddie on days off; everywhere possible when on holidays
    I'm beginning to research the possibility of having a LWB Series 2a body with a coil sprung chassis. At the moment the pipe dream is to use a 1984 Range Rover Classic chassis and drive line, place a 2a body on top and try to retain a 2a look as much as possible.
    I understand the wheel base is different and there my be body mounting issues.
    I want the Landy to resemble an older LR, however, I want it to be a very capable 4WD.
    Has any one come across this in Australia? I'm aware of one company in the states that make coil chassis for older LR's, however, it's not feasible.
    I look forward to some in put.
    Paul.
    Near Seven Hills, Sydney
    A table top might be easiest, using an LWB donor. Don't have to worry about the rear wheel arch lining up then or fuel tank filler placement etc.
    But then by the time you fit the V8 or whatever under the bonnet, you may have to have the radiator forward flush with the mudguards, losing much of what distingishes a Series from a 110 or Defender.
    Also, I believe the vehicle's identity is the chassis number, and all ADR's relevent to the chassis number's build date must be complied with, such as headlights in the guards not radiator panel, seatbelts, padded dash and so forth.
    Mark
    Williams West Aust
    Visit Discovery Automotives website.
    Julian there dis just that,it was featured in a 4WD mag a long time ago.
    Pretty sure he has a link to the project.
    ENJOY
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    99.87 MB
    This is a fascinating read from Outerlimits4x4. Make sure you also follow the links onto Pirate4x4 also as much of the info is in these threads also.
    Outer Limits 4x4 Board :: View topic - MogRover construction
    Slunnie
    Cranbourne North
    Yep I`m the proud new owner of a rrc/s3/defender hybrid ute.I cheated and brought one already done.As posted the radiator does end up flush with the front.Mine has the Isuzu 3.6 diesel,wich is a good fit with a reasonable amount of room around it.
    Cheers Hall
    Cranbourne North
    Jul 2008
    Thanks for the input I'm now gaining more momentum with my research and ideas. I do like the idea of having an isuzu engine transmission and gear box. However, I would like to keep original parts in the hybrid landy.
    Paul.
    Cranbourne North
    In my new toy it`s a Isuzu motor and the original range rover gearbox and tranfer case with a adaptor plate to makeit all come together.
    Cheers Hall
    Mar 2010
    South Africa
    I would like to bump this thread : I'm also doing some research on putting a 109" body on a RRC (100") chassis.
    Some issues come to mind:
    - lining up the wheel arches: since there is a fair amount of spare metal on a 109, I assume centering the body front-to-back and then trimming the wheel-arches to suite wouldn't be too much of an issue?
    - mounting the body: I assume fabricating assorted mounting plates and outriggers would be necessary? I haven't actually compared a RRC chassis to a 109 chassis....
    - front and rear cross-members: the RRC chassis doesn't really have them, I suppose I'll have to steal those off a Series chassis?
    - front grill & bonnet: depending on how I position the bulkhead, I suppose I'm going to struggle to squeeze the 3.5 V8 into the available hole?
    Does anybody have a chassis dimension diagram for the RRC? I have one for the Series 3, and I assume the series 2a is fairly close.
    Jake,
    Series rear crossmembers are available aftermarket, you are better off using one of those rather than cutting off what is probably an already rusty example, and if its not rusty, its too good a chassis to cut up
    The front crossmember on a series chassis is a simple box section albeit with crank/pto hole, below the radiator, and would probably need moving if you put anything but a Rover 4 or 6 in it anyway.
