Gday All,
This is just some pics so you can see how the prawns will arrive.
This pic is 3x3kg ctn next to a 9kg outer..So inside the outer will be
3x3kgs Endeavours
6x1.5kg tigers, or a mixture of both depending on YOUR order
This is the back of the 9kg outer.
It will have YOUR name and what is inside the box clearly marked..
If 2 orders are put together I will wrap each one seperate and mark it before it goes inside so it wont get mixed up.
Hope this makes it a bit clearer as to how they will be packed when they arrive..
Thanks and Cheers Ean
