There's nothing to worry about in regards to lining anything up.
If you're fitting greasable unis, get the nipples lined up so it's easy to grease them. That's all you need to worry about.
The only thing that should be marked before pulling apart is the sliding joint.
What should I have marked, and what do I do now? Is it a 1 in 4 chance of positioning it right now? I haven't pulled the shafts apart at the slider part, and don't intend to.
Thanks.
and it was my ticking noise I'd asked about in another thread(
. My 87 RR has all 4 the same.
