Results 1 to 4 of 4
Thread: TD5 Turbocharger Oil Feed Pipe - Leak
    Jan 2008
    4510 QLD
    Hi All,
    Has anyone had to replace the oil feed pipe? Mine has developed a small leak where the braided pipe is fitted to the rigid pipe. Turbo end of the connection seems straight forward, what is the fitting at the engine end?
    Replace with OEM or have it repaired?
    It's a union type fitting,(assuming I have the correct one) like the gearbox oil cooler pipes, probably just as easy to replace it rather than repair it, unless you have the tools etc to do it I suppose...
    Oil drain pipe (turbo) part No PNH101840
    Ean Austral Guest
    Are you sure that its not dripping off the oil filter onto it.
    If its the 1 I think it is, its a pain in the arse to fit the bolts in unless you have 10 year olds hands.
    I had to do the gasket behind the filter housing and putting that pipe back on took longer than putting the turbo on..
    For what its worth in my expierence with those type of hoses is replace it instead of stuffing around with it cause I've seen them leak further up the hose and the oil runs down inside the braiding and you think its the fitting at the bottom....But yours might be different..
    Good luck with it
    Cheers Ean
    Jan 2008
    4510 QLD
    Thanks Gents.
    UP, thanks for the Part Number.
    Ean, I ruled out all other sources around the hose, unfortunately for me, it's the fitting. I agree with you regarding replacing the part.
