Thread: 130 HCPU Rear wheel carrier
    Nov 2007
    Gold coast
    Does anybody make these, have not had any look with Mr Google...
    When I was looking at buying a 130 earlier this year I test drove one in Brisbane that had a rear wheel carrier on it.
    I asked where the carrier came from and the bloke said it was from an import Toyota Surf. He picked it from the wreckers and graphed it onto the driver's side corner. It was a pretty good fit. It didn't hinder the lights and the truck had been to the Cape and back twice with no signs of stress cracks on the top mount which bolted through the aluminium of the tub. I can't remember how the bottom hinge was mounted - whether through the aluminium or via the rear cross member.
    There was another 130 on ebay and carsales.com recently that had a spare wheel carrier hinged from the left. Do a search and you might get some pics.
    The other alterative would be to fabricate a frame coming up from the rear cross member.
    I am sticking with inside the tub location with mine at the moment...until I decide on upgrades
    Andrew
    Andrew
    1998 Landrover Defender 300Tdi 130 HCPU Expedition
    1972 Peugeot 504 Sedan - Daily Driver
    Gosnells WA
    My old man (brute) has a rear mounted spare.
    It hinges from a plate welded to the RHS grab handle that is attached to the rear cross member and to a plate attached to the top of the tub. It locks against the tailgate. and is incredibly solid. Will hassle him for pics.
    Ben
    Ben.
    Team W4 - WEBSITE
    VladTepes's Avatar
    Bracken Ridge, Qld
    Hmm still no pics Ben.. :P
    juddy I have a wheel carrier on my 130 - it was made by Kaymar and is "not bad" but I just had to have it re-done as it was worn and sagging a bit from much use over many years. I don't think Kaymar make one any longer. If you are up Brisbane Airport way or Redcliffe give me a call and you can come and havea look.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Gosnells WA
    I may have forgotten
    This is the best pic I have at the moment
    Ben.
    Team W4 - WEBSITE
