Results 1 to 10 of 12
Thread: Fuel gauge fault ?????
    macca72 Guest
    Cool Fuel gauge fault ?????
    I own a 2000 P38 4.0.....Recently It ran out of fuel on me with the gauge showing 1/4 tank and the low fuel lite didn't come on.Anybody got any ideas or had similar fault,Sender unit or dash gauge ???
    Ringwood VIC
    You car seems to be following my cars problems!
    Although I actually get "Fuel Gauge Fault" on the message centre. And every now and then I start the car and get an empty tank, then quarter, then returns to normal.
    I'm thinking its a bad connection somewhere, just need to find out where.
    Stu
    Try a can of EFI cleaner in about 1/2 tank of fuel. It may very well be contamination on the sender causing problems. The EFI cleaner dissolves the deposits on the sender...
    macca72 Guest
    Fuel gauge fault
    Nothing has appeared on the messages.It all appears to work as normal.
    It sits for weeks as I work in the Pilbara so the EFI treatment will be a good move.
    I will drive it on the trip meter and continue trying to sort itout.
    Your info and advice is greatly appreciated,,thanks.
    Coogee, South of Fremantle, WA
    Any updates on this? Same thing happening to me. Ran out of fuel yesterday ( thankfully outside a service station) and the gauge still showed 1/4 tank. Filled up , gauge showed full, have driven 150k`s and guage has hardly moved off full. Any ideas??
    The LR book indicates that with a full tank it needs to drop about 25L before there's any appreciable movement in the gauge off the "full" mark. I'd agree with that...especially if you fill the tank right up.
    Still no major movement after 180k`s but as my average is 13.5 ltrs per 100k`s at the mo so it could be ok just a glitch, fingers crossed with a 25ltr can full of fuel in the back.
    Nov 2006
    narellan, sydney
    how much fuel are you putting in when you run out? could there still 1/4 tank in there? you may have a crack in the pickup pipe or the sender unit causing you to suck air when it gets to 1/4.
    Andy
    Adelaide - Torrens Park
    I had to replace the sender in a HSE 4.6 once because of a similar problem.
    s/w metro of sydney , australia.
    sender went in mine .
    ME TOO, sender went at 240,000kms ish , did the same things above with 1/4 tank showing but ran empty /used speedo for refrence , got new fuel pump with sender ,put inside tank ////
    instantly fixed problem ,drove around tasie for 3 weeks the next week after it got fitted , and it still works from 6 years ago till now .
