Thread: D3 Diff Problem SSM 34304
    WazzaACT Guest
    Took my 2007 D3 in for a service today and mentioned that I thought there was a noise developing when driving around 100k's. When I called to see if teh Service was finished I was told I had a diff problem that was covered by SSM 34304 and that the diff would need repairs.
    Does anybody know about this and should both diffs be repaired?
    Wazza
    Nedlands, WA
    Not sure about the numbers Wazza,
    But there is an issue with pinion seals going in the diff, so that could be it. Causes a weep. Early diffs had a problem with paint causing the seals to deteriorate, but I beleive later models also had pinion seal problems (maybe from harmonic vibrations)
    They used to just replace the entire unit, but now I believe a kit is available just to replace the seals.
    Warranty.
    Douglas Park, NSW
    Quote Originally Posted by WazzaACT View Post
    Quote Originally Posted by Jamo View Post
    That's what the SSM is about.
    Seals are now available for front & rear diffs.
    WazzaACT Guest
    SSM 34304
    IS there somewhere that you get retrieve copies of SSM 34304?
    Douglas Park, NSW
