Results 1 to 10 of 12
Thread: DIESEL CHIPPING - COST v GAINS
    With the imminent purchase of the D2 and TD5 aproaching ever so closer, chipping is becoming a drawcard and a reason to part with some cheap cash.... if there is indeed such a thing....
    With the multitude of options out there, I came across Steinbauer at the recent 4WD show here in W of A.
    This is the link to the TD5 page http://www.steinbauer.cc/neu/pdf///S...5_102_kW_1.pdf
    and this is the link for the TDV6 http://www.steinbauer.cc/neu/pdf///S...6_140_kW_1.pdf
    And this for the Sport TDV8 http://www.steinbauer.cc/neu/pdf///S...8_200_kW_1.pdf
    Now, the analogy, $$/increase
    The TD5 - adds 20kW & 60Nm, costs $1952, = $97.50/kW and $32.50/Nm.
    The TDV6 - adds 28kW & 80Nm, costs $2865, = $102.31/kW and $35.81/Nm.
    The TDV8 - adds 40kW & 128Nm, costs $3327, = $83.17/kW and $23.76/Nm.
    This seems to me to be a little expensive, requires hooking into the existing system and doesnt look to be flexible or even really provide a fuzzy feeling in my pants.
    Has anyone got info on chip costs and gains?? Would be interesting for those who are seeking and those still not happy with their tweaking!
    Tombie, I expect an answer from you on this one! Chance to prove your worth so to speak!!
    Andrew
    Australia
    Do search on chipping the TD5.
    As you said, there a multitude of options and this one is laughable for the $ and gains being offered.
    For these $ compared with other options available, I would expect gains of 60kw and fuel consumption figures 20% less. (yeah I know its a silly ask)
    You will find options immediately available from Tombie, TRS, Davis, BAS & Discowhite (there are others which dont spring to mind immediately so sorry to those) for a nearly 1/4 of $.
    Around $500 to $800 including shipping/ loading of map, depending on what model D2 you purchase. (this depends on the type of ECU)
    All of the above folks will provide more bang for your $ than Steinbauer are offering and they are Landy nuts, so (IMO) have probably got a better clue and therefore mapping for a Landy.
    You can expect around 30kw minimum from any of these above and can go all out with some of the other maps and intercooler and exhaust upgrades approaching gains of 70kw.
    $16 / kw for the TD5 sure beats $97.50 / kw
    Manly QLD
    Quote Originally Posted by strangy View Post
    X2
    I've had the Tombie remap for a while, brilliant, no where near $1800
    Oct 2008
    Mines +90kw for 440 + I/C $500(I got mine 2nd hand)
    And a futher 20kw for $120 with the added boost (BAS boost box)
    And $90 for EGR removal
    And $130 for Silicon I/C hoses
    All up +110kw and over 200nm for 1280
    I think that is fantastic value.
    Ben...
    Im still not conviced that any chipped TD5 in Australia is 200kw.
    Lara who has probably the best and most modified td5 in the world, running 26psi, 2.8litres, huge turbo, tubular manifolds, and also head work is still just under 200kw (195kw-265bhp)
    [ame="http://www.pirate4x4.com/forum/showpost.php?p=10661200&postcount=227"]Pirate4x4.Com Bulletin Board - View Single Post - big gay truck wheelin[/ame]
    He also had axles made out of 300 maraging (same as F1) to cope with it prior to swapping out for Spider 9's
    Oct 2008
    Quote Originally Posted by Psimpson7 View Post
    That would be at the wheels.
    My guess would be that quoted kw with chipping would be at the fly wheel.
    For the record my std turbo pulls 25psi easy
    Quote Originally Posted by Benny_IIA View Post
    Dont think it is.... 'p-weil' is power at wheels I think and thats 166.5kw
    Jun 2008
    McMinns Lagoon NT
    Don't know figures on my TRS chip and intercooler upgrade but I am more than happy with the increased pwoer and torque that the $1700 bought.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Oct 2008
    hmm... maybe i did read that.
    need tombie to weight into the discussion.
    Yeah Tombie's input would be great. Dont get me wrong I think his chips are excellent, I'm just not convinced by the 200kw figures that get banded about.
    Would be interesting to see a RR result, and I would happily eat my hat if 200kw came up!
    I spent years building, modifying, and mapping my own race engines and getting that sort of percentage power increase take a huge amount of work to do reliably.
    Rgds
    Pete
