Results 1 to 10 of 23
Thread: Solar dilema
    dkwilson Guest
    Solar dilema
    My dilemma.
    I have 5 solar panels, 2 new 40w and three old Solarex 40w panels. They are all 12v panels – approx 19-20v open circuit. Are they compatible to hook up together. I intend to use a Morningstar 15 amp Sunsaver MPPT regulator. I propose to use two sets of panels each hooked up in parallel and then connected together in series then to the regulator or controller. Would the “parallel then series” set up improve the compatibility of the two sets of panels given that the voltage would be the sum of both sets. The controller apparently can handle the voltage.
    Next question. My vehicle, Disco 2, has a calcium battery and I think a 140 amp alternator. For vehicle charging of the leisure battery when underway will the Disco set up harm an AGM if it whacks it with some heavy amps? Isolator and cables are more than adequate (Redarc and 2 B&S).
    May 2009
    Tatura, Vic
    If it was me I would just run them all in parallel.
    Just make sure you mount the regulator near the battery not on the panel.
    If your aux battery is a medium to large the alternator won't hurt it.
    Dave.
    depending on the input voltage of the regulator I would suggest that a full 12v in parrallel setup with high quality blocking diodes would be the best bet although thats potentially going to cost you a couple of hundred mA per diode/panel.
    But it does stop partial shading causing headaches.
    If you can set the array up so that all panels get lit you can do without the blocking diodes and run a parallel setup but when one panel dies it will pull the power out of the system.
    if you flatten the AGM and then dump 140 amps from the alternator into it its not going to like you very much. Id suggest putting something in that will act as a current limiter if you plan on flattening the battery too much but this wont be a problem if you keep the battery inside its normal operating spec.
    May 2009
    Tatura, Vic
    Dave,
    Can you explain what these blocking diodes are for?
    I have two 80 watt panels which I take when I go camping. I have one connected to the car to run the engle and the other to the caravan to run lights and water pump.
    As 80 watts is a bit of overkill for the caravan I have made up a lead to connect the two in parallel to run the engle on a cloudy day.
    This will deliver about 5 amps each when sunny to about one amp each when heavy cloud.
    Ok, lets say the sun is shining and I am getting five amps x two and the wind blows one of them over and therefore one is out of action, don't I still get five amps from the other one?
    Dave.
    May 2006
    Carlton, Melbourne
    The only advantage to running them in a series then parallel config would be to double the voltage, which would reduce the current, which means longer cable runs for the same voltage drop, but you have 5 panels, which means one panel left over. you should only series identical panels(same age etc), so two sets, one set of new panels in series, one set of old panels in series, then parallel the outputs of the two sets.
    Thats a lot of wiring to put together on site!
    If you just parallel the lot, they can all "piggy-back" off each other, so you can add and remove panels as you wish.
    The MPPT regulator will pull the voltage down to the point where you are getting maximum total output from whatever panels you add.
    Fraser
    the panel may still be outputting 5 amps but the one thats fallen over will now be drawing current.
    if you think of it like a pair simple permanant magnet generators in parralell while both are being driven your getting power out of both of them. If you remove the drive from one it will carry on spinning becasue its gone from being a generator to a motor. The output from the generator thats still being driven goes to making the undriven generator turn instead of into the batteries.
    a blocking diode also forms the simplest form of charging regulator because it stops the battery from discharging into the panel when its not providing charge.
    Aug 2009
    Brookfield Melb. Victoria Australia
    Hi I was wondering if or how do I measure amps, I have a digital multi meter and it tells me how many volts my panels are putting out but have no idea how many amps??
    Andrew
    May 2009
    Tatura, Vic
    Andrew,
    Most digital multimeters usually have a current measurement of ten amps.
    If you have this you will need to unplug the non common lead and put it into the current measurement jack. You then remove one of your solar panel leads from the battery and connect it to one of the multimeter leads. Then connect the other lead to your battery. Don't worry about which way round the leads are. If it is wrong you will just get a minus before the reading.
    The above procedure is known as connecting the multimeter "In series"
    Dave.
    Aug 2009
    Thanks Mr Whippy I will try it out soon as the sun comes up.
    Andrew
    May 2009
    Tatura, Vic
    Andrew,
    I assume then that your multimeter has amp measurement.
    It is easy for me as I have a hi tech solar regulator which tells me amp input as well as many other things.
    Dave.
