2nd December 2009, 08:56 PM
D2 V8 Low power below 2000 rpm and slight stall
Just had the oxygen sensors replaced, so the D2 does not blow smoke anymore but still has a slight stall below around 2000 rpm.
It only seems to do it under slight aceleration.
There was a fault read for the airflow sensor and lambda sensor but did not return after being cleared.
Any ideas apreciated.
