Results 1 to 10 of 13
Thread: Defender 110 swivel pin bearings
    Jan 2008
    Hi,
    I have a 1999,110 defender td5, without abs, can anyone tell me if it is possible to use the same bearing on the top and bottom of the swivel housing, that is using part no. 606666 on top and bottom.
    Thank you,
    Papadad
    Dec 2008
    Kenya
    Yes. Later models had no bearing on top of housing I think but all use 606666
    Kingston, Tassie, OZ.
    Yes, non ABS models are 60666 top and bottom.
    JC
    Yea, Victoria, Australia
    Is this the same for all the earlier models. I have a 110 V8 which needs new swivel bearings..
    Rich
    Jan 2008
    Hi,
    I may have asked this already but can't find it so here goes.
    Defender 110, 1999, TD5, no ABS.
    I'm going to replace my wheel bearings and swivel pins, can someone tell me the rover part number or a vender part number for the top swivel pin bearing,
    its not 606666, this much I'm sure of. The existing bearing has no name or number on it, probably made of monkey metal.
    Thank you,
    rover000101
    kurandabed@tpg.com.au
    Jan 2008
    Gladstone, Queensland
    Quote Originally Posted by papadad View Post
    You certainly posted a similar question. You've only ever made 23 posts so it was dead easy to find by asking for all posts made by you.
    Threads merged.
    JC
    hey Justin,
    They're not all the same I am afraid. The top bearing is different.
    I found that out the hard way when putting mine back together.... (01 no abs)
    Rgds
    Pete
    Jan 2008
    defender 110 top swivel pin bearing
    Thanks for that Pete, thought I was going mad, so does anyone have a part number for the top swivel pin bearing, its not 606666. I have a swivel pin kit TAR 100040 but the bearing looks to be made of "monkey metal" and the local bearing shop suggests I throw it away, same with the wheel bearings p/no.
    NP449291, they don't look very strong.
    Papadad
    Hi PD,
    I wish I did. I had my whole car apart when I spotted that, and ended up having to take the new bearing tracks out of the top of the new swivels, and then put the old ones from the previous swivels in.
    I cant find the number either at the moment. i will have a look through my parts books this evening and see if I can track them down.
    Interestingly the ones I got that were wrong came from LR and they had the Vin number to order against.......
    Rgds
    Pete
