I think I'd be trying another electrician.
If you have parking lights & the high beam operates when you pull back on the switch (flash mode), then the problem is going to be in the dip/indicator switch istelf. It's a very common failure point with the Defender.
Once it's sorted, fit some common relays to the lights or get a Traxide kit (easier).
 has never bought this relay from Land Rover & they have quite a few Defenders through there.
