Results 1 to 10 of 22
Thread: Td5 Defender fuel pump answers
    Ok the fuel pump issue, I'm about to put in my 4th with 150k on the clock. Let me say from the onset I have a 127L long range tank. All of mine have failed with what starts out as a louder and louder whine, soon followed by starting problems. If I can get it to start I have never had one actually stop me while I'm driving (seem a loss of power though).
    What I know about them;
    1. They seem very sensitive and fail easily due to;
    - Any blockage from bad fuel or debris in the tank.
    - Cavitaion caused to air in the system which occurs through connection plugs at top of pump, at a porous seal on top of fuel filter or through injector seals leaking air back into the fuel system. Cant be from a split fuel hose as the whole system is under 4 bar of pressure(??).
    2. They are expensive to replace (around $800), with a part that has not had an upgraded design. Aftermarket pumps are cheaper if ordered direct through the UK.
    3. You do it once then cut an access hole in the floor. Otherwise dropping and refitting tank will result in brocken fuel hoses with fixed one piece connections.
    Could anyone help me with the following;
    1. Does a Discovery pump work (it's cheaper).
    2. Is there an aftermarket brand that is of higher quality?
    3. There seems to be a conection with the longrange tanks and increase in failure. Anyone else with a longrange tank agree?
    4. Has anyone actually repaired the pump itself.
    5. What is the longterm fix, apart from an external pump as I have read on serveral forums guy's doing.
    Any discussion on this would be great as I'm lost on this and this problem has caused me a huge amount of drama and financial cost. Thanks in advance for any input.
    Brett.
    Quote Originally Posted by nornalup View Post
    1. Does a Discovery pump work (it's cheaper). sender calibration will probably be wrong for gauge. depth of pump may also be wrong
    2. Is there an aftermarket brand that is of higher quality? not to my knowledge, and some of them are probably even worse.
    3. There seems to be a conection with the longrange tanks and increase in failure. Anyone else with a longrange tank agree? from what I have read I would agree. I am sure somewhere I read some comments that issue may be down to the fact that the plastic tank is kinder on the pump withr egard to flexing and so on.
    4. Has anyone actually repaired the pump itself. nope
    5. What is the longterm fix, apart from an external pump as I have read on serveral forums guy's doing. I would consider going to an external pump but it wouldnt really be that much cheaper by the time you had done it the first time, although the pump would no doubt be more reliable, so would save money in the long run. You would also ned to make sure you could keep the self bleeding set up, and be aware that fuel is filtered twice through the fuel filter.
    My comments in red
    The disco pump will work, its the same but on a slightly longer frame.
    as near as i can work out most of the long range tanks are steel tanks and steel tanks are marginally more prone to depositing junk into the fuel as well as being maringally more prone to developing diesel snot. diesel snot once injested into the pump will end it quickly.
    I have 2 dead pumps and have on an on and off basis been experimenting with differnt styles of pumps to modify it with. I'm yet to come up with a locally provided solution that is doable in a typical home garage that has the reliability Id like to see, is near enough in performance as to make no difference to the fuel system and is cheaper than importing a pump from the UK. I have had some limited sucess with what I would call a temporary get you out of trouble fix but it bypasses the inital filtering and Im not sure that its going to be a viable medium term fix so I havent published anything about that yet.
    the best long term fix I have come up with is similar to the efforts of the guys on other forums and involve replacing several parts of the fuel system but should provide a long term answer with better serviceability than the existing system. BUT...
    1. my fuel pump hasnt failed so I havent had a need to try out what Ive theorised
    2. I dont know of anyone that can do without their td5 on the road while I gin around sorting a new fuel system.
    Thanks for the input guy's. Just how many of these have guys had go on them? Am I an exception? Reason for asking is that perhaps I have a issue that is causing the pumps to fail (3 in the last 40k, although this has been over 3.5 years). The reason could be;
    1. Algae and crap in the tank. I did have this cause one failure after I started using a fual additive and it sent all black slugde loose.
    2. Bad fuel. I don't think this is the issue as i fill up from same place EVERY time on an account. No one else, including dozens of farmers using machinery, have had an issue. No jerry cans and for gods sake what the heck would happen to them in places like Africa filling from a rusty 44.
    3. An air leak in the system. It's not a fuel hose as my theory is as the system is under a pressure meaning a hole letting air in would be detected by diesel leaking out. The exception to this is an air leak at the top of fuel filter and at the seals on the injector. From forums the later would be detected by fuel leaking into the oil, which you would smell at the dip stick. The former would be fixed by replacing the fuel filter and seal, which I do on a regular basis.
    4. A really poor designed pump combined with the long range stainless steal tank. But this goes back to the question of how common an issue is it. Two dealers and a spare parts supplier in WA tell me they get a few disco but not really any defender fuel pump failures
    5. An electrical issue causing the pump to work harder than it has too. Jeez I don't want to even think about testing and solving this one.
    Perhaps I've been really unlucky and 4th time lucky. But I'm really not keen just to throw another $800 pump in her and hope.
    Brett.
    Ok just an update from our local dealer. Original pumps are now priced at $1090 for part only (no fitting). He believed they have been superceeded by an updated part but could not say wether they have improved part or simply changed part #.
    I had a genuine 90 one landed from the UK for under 550$ about 5 months ago.
    Thanks, do you remember who from, most I have looked at in the UK online are aftermarket. The other option is to fit a discovery one, although it's said it can be done I have not heard of anyone that has actually done it to their own vehicle.
    Oct 2008
    One thing to check is the breather system for the tank, if the tank breather is blocked the air pressure drops inside the tank, which can cause cavitation. Check the breather is not blocked with mud.
    I've had a 127 LRA tank in mine for 180,000 on it's original and still silent pump.
    Oct 2008
    Oh - Also I've never let the tank get below the red light, so there's always at least 30 l in the tank, I've read that if you get the tanks too low with a Long range tank then the pump can get too hot.
    UK main dealer near where my brother works. He posted it over so that also included VAT. Direct they should be able to match that.
    A d90 pump from the dealer on the Gold Coast is about 1900$ last time I checked.
    I destroyed one due to my stupidity, and the one I bought recently is just a spare for trips
