Results 1 to 10 of 12
Thread: Bonnet prop rod - photos please
    Logan Village area S.E. QLD
    We have Scallops "Matilda" here for a visit to get her ready for a roadworthy and registration..
    Matilda has no Bonnet prop rod (we are using a bit of wood..most unlady like) so can we have photos and measurements so we can make one
    thanks
    Series Landy Rescue
    Our FB Page..
    Quote Originally Posted by Numpty's Missus View Post
    You have a thousand series LR's in your yard....rat one off one of them
    AFAIK from memory they are basically the same if not identical
    they are not the same we tried that...series 1 is in the middle of the bonnet and the later series don't fit it fowls on the motor
    Mrs ho har
    Series Landy Rescue
    Our FB Page..
    Nov 2006
    Wollongong NSW
    86" bonnet prop
    10 mm dia
    2 foot 1 inch long to pivot rivit...
    bracket 2"x2"x1 1/2 with a kink along the centre
    so bolt heads is level with inner guard..............
    Nov 2006
    Wollongong NSW
    Quote Originally Posted by groucho View Post
    86" bonnet prop
    10 mm dia
    I might have stuffed up Thinking........
    it could be a 80" one on a 86 guard
    hmmm the bracket for this one is beside the radiator
    Mrs ho har
    Series Landy Rescue
    Our FB Page..
    Jul 2009
    S.E.Qld
    I've got a spare one I'd be willing to part with.(part no 303956) I don't have the bracket that bolts to the radiator panel . S1 86 /107 on passenger side ,88/109 drivers side.Same rod different bracket.If you're interested PM me.
    the bracket is on the raditor and the bonnet...scallops just needs the rod...he is down the shed working he will PM you when he gets home
    Mrs ho har
    Series Landy Rescue
    Our FB Page..
    Jul 2009
    S.E.Qld
    Slight mistake! On the 86/107 the bracket is bolted to the mudguard,on the88/109 to the radiator panel.
    Yass NSW
    On my 1956 107, Passengers side mounted. Top rod is 369mm, bottom rod is 401mm
    If you need more detail I could probably remove it and take some proper photos.
    Regards,
    Tote
    Qld.
    The bracket to take the bonnet prop mount looks original to me and is not at the side as per the Series 2's and 3's that lie all around me! - I think we'll just make one using the measurements provided - thanks everyone for your help.
    As mentioned - mine is a 86 chassis (1955) with 1957 engine, axles and panels. It's all a bit confusing.
    Got heaps done today - I'll post a thread later with all the details - if Kat lets me "waste" more time today doing LR stuff!
    2007 Defender 110
    1993 BMW R100LT
