I was in the same boat a while back, however it was on a 92 RR so the plenum cover may be different, but the 2 pipes will go back to the intake manifold on the passenger side at the front. And from what I could tell, the chamber did little more than warm up the air on it's way into the engine.
So really you could just bypass it, or proper fix remove plenum cover and new gasket.
When I cleaned my plenum cover up when I did the top end, that chamber you speak of was fully blocked with dry coolant. The gasket is very simple and just a square piece of card with a 10ish mm hole at one side. So if you get some 0.5 - 1.0 mm gasket paper you can very easily make your own. If the little chamber is clean I would say it would take next to no time to sort out.
Ben
[/IMG]
