Results 1 to 10 of 16
Thread: Please recommend me some recovery gear
    MobyDisco Guest
    Hi All,
    It's time to take the Mobydisco D3 off road. We're planning to start simple ... the trails and beaches of Bribie Island.
    What recovery gear do you recommend I buy before setting out?
    I think I need:
    * a compressor (any recommendations on which one to buy? Happy to spend more for something fast and fully featured)
    * a snatch strap rated to 8000Kg (which one?)
    * a recovery damper
    Anything else? All advice appreciated, thanks.
    **Discovery300Tdi** Guest
    Quote Originally Posted by MobyDisco View Post
    Hi All,
    I think I need:
    * a recovery damper
    Mate all my gear is from arb. If you go see them and let them know what sort of 4wdin you intend of doing they will help you out. Your basic gear should consist of ....
    - snatch strap
    - tree trunk protector
    - equalizer strap
    - winch extension strap ( if you have a winch)
    - x2 rated bow shackles
    - if no winch - a hand winch (magnum)
    - you can get the dampner but I just use my arb bag
    - and a niffty arb bag to store everything in.
    As in regards to a compresor I got a portable arb one. It comes in it's own little box with all connections and fittings are they are great.
    Hope that helps.
    Simon
    MobyDisco Guest
    Thanks Joker. There's an ARB near me at Strathpine, so I could get there easily and have a word to them about what I need.
    You will need to replace the scissor jack that comes with the D3 (and D4 I assume) as it is unsuitable for use on anything other than level concrete or bitumen.
    Jock The Rock Guest
    I have never been a big fan of ARB gear
    You pay the earth for the stuff and its more often than not, just as good as anything else
    (I'm not saying don't go there, just don't buy anything there until you have a look around)
    There are some good things that ARB make like Lockers etc but no way will I be paying $180 for ARB's top of the line snatch strap
    Have a shop around before you splash out your hard earned in any of their shops
    Check out eBay, your local TJM store and other places
    Black Rat Snatch Strap (Recovery Kit) & Bonus Gift - eBay 4x4 Accessories, Exterior, Car Parts, Accessories, Cars, Bikes, Boats. (end time 07-Dec-09 15:37:21 AEDST)
    IRONMAN SMALL RECOVERY KIT SNATCH STRAP SHACKLES HITCH - eBay 4x4 Accessories, Exterior, Car Parts, Accessories, Cars, Bikes, Boats. (end time 29-Dec-09 14:16:52 AEDST)
    If you place any faith in 4WD magazine tests, a couple of years ago, a snatch strap from SuperCheap outperformed all the name brands.
    Of course places like that often change their suppliers, so the same one might not be available now.
    Sand Driving:
    2 x rated recovery shackles
    Snatch strap
    Jacking plate - 60cm x 60cm square of forming ply will do
    Bottle jack - as mentioned you have a scissor jack which is bad news, make sure to get a large enough bottle jack to fit the vehicle
    Compressor - new ARB ones are actually quite good, but make sure you get one rated for continuous use.
    Recovery points - front and rear. Rear point is easy, just buy a tow hitch receiver (usually comes with a shackle). For the front have a search on the forum.
    Shovel - have a look at 4x4 Accessories - Off Road Shovels - Combo Shovel
    E-Z-Deflator from ARB - well worth getting or you can get Staun's
    Good tyre gauge (from when you re-inflate the tyres).
    If the front recovery option is two recovery eyes on a bullbar or on the chassis rails then an 2 extra shackles and a small equaliser strap is also essential.
    Like others I'm not a great fan of ARB but some of their equipment is good. The added advantage is it gives you a one stop shop, however I tend to find they are also very poor on knowledge of anything other than a Toyota off-road unless you talk to their head office.
    Stockton, NSW
    Dont forget the UHF! very hand when recovering someone or being recovered...
    Central Coast NSW
    BCF stock Australian made "Just Straps" and they are as good as you will get any where.
    Various kits available. For about $300 they have kit with the works !
    Check out "Just Straps" web site for inventory.
    I have a new ARB portable compressor and goes like a rocket and no problems (so far)
    MobyDisco Guest
    Thanks guys, I really appreciate your advice.
