7th December 2009, 10:03 AM
200TDi Injectors
Does anybody know [for sure] where to get 200tdi injectors rec`ond
7th December 2009, 11:13 PM
Usually, it's easier to get a new set from the UK - Paddocks spares is the best, however, I couldn't find a listing for a 200tdi injector at the moment.
Otherwise, it is a case of fronting up to a decent industrial diesel mechanic and saying the words 'bosch injector' without saying 'Landrover' or '200tdi'. Saying 'Landrover' to certain people in Australia tends to make their ears automatically close and they automatically shake their head from side to side.
This thread from another forum should give you the part numbers
200Tdi injectors - LR4x4 - The Land Rover Forum
and armed with that info any decent and accredited Bosch diesel outlet can order in new parts, rebuild the tips and check the burst pressures.
( If you are carefull, one can dissamble and clean the tips DIY - I did)
New tips are quite common with VW diesels, as they use the same injection system.
8th December 2009, 01:54 AM
Injectors
Many thanks, just the sort of inf. I was seeking
