Results 1 to 6 of 6
Thread: help with starter motor
    Jul 2009
    victoria
    hello all.
    the other day my starter motor undid itself from the pinion end and fell off inside the clutch housing. upon retrieving the loose parts i noticed that a few of the parts were in fact no where to be seen.
    now i am stuck without a starter motor and at the moment i cannot afford a new one. all i really need is the 2 sleeves that sit either side of the pinion assembly. i have tried all parts suppliers and have had no luck.
    is there any thing someone can suggest to help me back on track? i would get the 2 sleeves turned up on a lathe but i dont even have an original to use as a template.
    any help would be greatly appreciated. MR
    use the crank handle
    Dec 2008
    Quote Originally Posted by marcello View Post
    hello all.
    What sorta Landy?
    JDNSW's Avatar
    I don't know what parts suppliers you have tried, but I suggest rather than Landrover parts suppliers, look for a long established auto electrician. A second alternative would be to look for a 'dead' starter rather than just the rings.
    I don't know which parts suppliers you have tried, but have you tried Fred Smith in Wantirna? He seems to have a large number of dead Series Landrovers and I would be surprised if he could not sell you a second hand starter or lend you one to measure the rings.
    numpty's Avatar
    numpty is offline TopicToaster Silver Subscriber
    Nundle
    Quote Originally Posted by Mudsloth View Post
    What sorta Landy?
    Seeing that the post is in the S11/11A section, one would assume it's a............S11 or 11A
    Numpty
    REMLR No 143
    Jul 2009
    victoria
    thankyou to all who have responded. i apologise for not being clear with the details. the car is a series 2a.
    i believe i have found the correct parts on ebay. if this is no help then at least i know what to do next. thankyou.
