Results 1 to 10 of 23
Thread: Lucas 2 button fob to replace Valeo fob/key?
    Dec 2009
    G'day all,
    Being new to this forum, I'm hoping someone can assist in answering a question that I'm sure has been raised in the past.
    As the owner of a D2 TD5, my ignition key incorporates a 2 button Valeo fob - of which I only have one.
    I’m in need of a second key but am not keen on paying the $400 plus being charged by Land Rover stealers.
    Being an Australian delivered vehicle I know that my system is operating at 315mHz, so can I therefore use a brand new Lucas 315mHz 2 button fob and a separate key?
    I understand that programming the 2 button systems can only be achieved by stealer with testbook (unlike the D1 single button systems that can be programmed with a sequence key turns and door/bonnet locks), but this should cost less than $100. Coupled with a $40 for the new fob & $10 for a key blank, this works out to be a fraction of the cost for a Valeo 2 button key/fob combo.
    I look forward to any responses.
    Douglas Park, NSW
    Quote Originally Posted by fisherolf View Post
    Early D2s were 315MHz then they changed to 433MHz.
    Along with the remote, you need to make sure it comes with the barcode too.
    Dec 2009
    (Just wasted 15 min of my life replying to your message, only to have it disappear when I was logged out!!)
    Thanks for your quick response Scott.
    I’m probably showing my profound ignorance, but is my understanding of the security system flawed?
    I thought the key barcode was only necessary if the vehicle could not be accessed (ie all keys either lost or no longer functioning). The barcode could then be entered into the "Testbook" to allow synchronisation of the fob with the vehicles security system?
    As I have a fully functioning key and can therefore turn on the ignition, doesn’t this mean that the "Testbook" will communicate with the vehicle security system – negating the need for the barcode?
    I was of the understanding that once in "learn" mode the vehicles security system scans the 315 mHz frequency for valid codes (which are then mapped to the security system memory)? Pressing the "Lock" button first followed by the "Unlock" button of the first fob programs the 2 functions; and then up to 4 fobs (was only 2 for the single button D1 fobs) can be subsequently programmed, but they must all be programmed in the one "learn" session?
    I certainly don’t want to waste money on a Lucas fob if the programming cannot be done, but more importantly I don’t want to look a fool by presenting my Lucas fob to a Landy Stealer with a task that simply cannot be performed!
    I welcome any input on the subject. Should my endeavours prove successful, I’m sure many will benefit with savings of around $300 a pop!
    Thanks again
    Rolf
    There are 2 barcodes with a new key. One is the key's ID the other is to presync it to the BCU unit. These are programmed in to the BCU with Testbook or Rovacom etc software.
    The other fob you've shown is from the Lucas10AS unit fitted to D1 and Td5/Puma Defenders. This can operate on the same frequency as the D2 but sends an entirely different code and does not need to be authorised on the BCU. It won't work with the Valeo unit in the D2.
    Dec 2009
    Thanks for putting me on the straight and narrow.
    Given that a Lucas fob won't work with the Valeo system, is there a cheaper option than purchasing a $400 plus key from a stealer??
    Williams West Aust
    You could try a few of the wreckers,problem is they know what a new one is worth.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Dec 2009
    Can a secondhand Valeo key/fob be synchronised to my vehicle security system without the necessary barcodes?
    May 2008
    Mudgeeraba, QLD.
    Rolf,
    I have just received a new key from the UK. $173.00 landed in Australia.
    Approx $5.00 to have the blank cut. Was able the program it with my Nanocom. Try here.
    LAND ROVER DISCOVERY 2 TD5 & V8 ALARM KEY FOB & KEY on eBay (end time 06-Jan-10 17:21:11 GMT)
    Dave.
    Dec 2009
    Thanks David, $173 certainly beats the $400 plus asked by the Landy stealers !
    Do you know if there is anyone in Melbourne that hires out Nanocoms or similar diagnostic machines?
    Williams West Aust
    HEAPS of us TD5 owners have a Nanocom,they are really a must have.
    There is a list of owners willing to help others with their Nanocom in the Electronic Diagnostics forum.
    Andrew
