I would get this looked at. That's definitely not normal.
Sounds normal.. except there is noise in 4th and 5th gear like a gearbox whine. the noise is there just in 3rd when feathering the throttle and also 4th.. if you accelerate hard then the noise in 3rd and 4th isnt as bad.
after a bit of a search am i assuming that the transfer case may be a bit low on oil?
or... is this normal? the gearbox has a lot of vibrations through it too... but as im used to a disco II td5 auto.. i dont know if this is all a normal thing
The TC oil can be easily checked but a slight whine is quite common.
